メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
Face iD Not working due to proximity sensor failure.
I have a iPhone X on which I performed a screen repair, Iam a regular worker and know my stuff. I performed all the steps which are necessary to retain the face id and I succeeded too but only temporarily. After a month or two my face id stopped working, my phone's proximity sensor doesn't works due to which true tone has also vanished. Portrait mode does not works either. Can anyone help me out on how to restore proximity sensor? I know for sure if i get it up and running again then face id will work like a charm. Any suggestions, ideas, help will be appreciated.Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
hello ashhad,
I wrote to someone about such a problem a moment ago - it still happens. Make sure that the proximity sensor is not working: call your inbox and cover the mesh of the speaker with your finger during the call. If the screen turns off - the sensor is working. Additionally, make sure that the light sensor is working - put a working phone under a strong light bulb - if the screen brightens by itself, the sensor is working. If any of these tests fail, write - I'll tell you what to do next.
In general, you will need to test voltages and resistance check the entire tape of the talk speaker along with the sensor bank and the "Flood Illuminator" sensor.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have the same problem. Bought a new sensor with flex. I cleaned the sensor and Face ID still is not available
さんによる
Light sensor not working
さんによる
コメントを追加
Your Earspeaker flex might be torn or broken ribbon. So transfer the parts like proximity sensor and flood illuminator from old to new flex.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This requires some pro level skills and equipment both of which I don't have......
さんによる
コメントを追加
回答を追加する
ashhad nizamani さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 37
今までの合計 1,023
