メインコンテンツにスキップ
2013年6月に発売されたAppleのワイヤレスベースステーションの第6代目モデルです。タワーはワイヤレス接続を可能にするデュアルバンドを搭載、Appleの最初のルーターである802.11acテクノロジが組み込まれています。
Can not reconnect cables to logic board?
I just opened my A1521 Airport Extreme to clean and lube the cooling fan, trying to solve the overheating problem. Everything has gone back together nicely until I got to the last step of connecting the two small connectors to the logic board. One of these goes to the indicator lamp, not sure about the other. After an hour of trying, I’ve had no success in getting the connectors to snap into place. The back of the connector is virtually smooth, so I don’t see how it is supposed to connect. It does not appear like the connectors broke when I removed them, but it seems like I’m trying to connect a smooth connector to a smooth surfaced circuit board. How are these supposed to connect?
Update (07/18/2021)
Dan, that’s exactly what happened, I can now clearly see that both parts of the connectors pulled off of the board. The tear down instructions gave several warnings about being careful to not break the connector, and I was impressed with how easily and cleanly mine came off. Perhaps I will add a comment about what happened here. I left the reset switch connected to the board, and instead disconnect the actual switch from the case. My problem is with the LED and whatever the other is directly next to the LED. What is that one?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@charles218 post some pictures with your QUESTION of what your cables and board connectors look like. That way we can see what you see iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
3件の回答
ベストアンサー
Ouch! It sounds like you lifted the logic board connector off with the cable connector!
Click on the image to enlarge
If that is the case you’ll need to see if your logic board can b fixed otherwise it’s time for a new one.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If I remember correctly, one is an LED and the other is the reset button, they should not be critical components. If you tore the connectors, leave them be.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The 4 pin fan conn attaches to the Logic Bd conn. Do not remove the old fan connector! Cut the old fan wires and splice all 4 wires to the new replacement fan wires in proper order. Use heat shrink to insulate the solder joints on the wires. If you try to remove the old fan conn from the board you’ll never get the new fan conn on without breaking something! Trust me!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Charles Larkins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 221
