メインコンテンツにスキップ
Fitbit Charge 2の修理情報です。2016年に発売されたものです。型番は FB407です。
Display flipped after replacement
After following the screen replacement guide here: Fitbit Charge 2 Touch Screen Assembly Replacement, the display is flipped, dim, and has a vertical bar of static on the right side.
I have tried reseating the ribbon cable several times, with the same result each time. Before removing the old screen, it displayed correctly. I’m not sure what else to try to fix this problem. Any help would be much appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
There was no problem with the new display, the problem was in software. To fix this problem, I did a factory reset of the device. To do that, I followed the guide here: https://www.lifewire.com/how-to-factory-...
  1. Go to the Fitbit website www.fitbit.com and log in.
  2. Select the gear icon in the top-right of the screen and then select the device to be reset in the drop down menu.
  3. Scroll to the bottom of the screen and select the option to remove the device from the account.
  4. Add the device back to the account as was done for initial setup.
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
The guide for factory reset is outdated; www.fitbit.com redirects to store.google.com, so you cannot use this website to reset anymore.
Seems that there are three possibilities to reset, but this needs confirmation:
1) Use the Fitbit app to sync the device, then remove it from the app and set up a new device.
2) While plugged in and charging, hold the physical button until the unit resets.
3) Use the Fitbit Connect app for Mac or Windows
さんによる
コメントを追加
回答を追加する
Brennan P さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 267
