メインコンテンツにスキップ
The Sony Handycam FDR-AX33 is a palm sized camcorder that combines 4K video with video stabilization. It was released in March 2015, and was the first camcorder to introduce the new Balanced Optical SteadyShot (BOSS).
8回答 すべてを表示
screen goes black and I have to reset the camera
I also have this problem that just started occurring. Also the screen goes black and I have to reset the camera. I am looking into a company called Camera Repair Center to send to for repair. Did anyone find a solution other than sending it in?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @Simon Marsh,
Don’t know the answer but here’s the service manual for the camcorder. Be patient as it takes a little while to go from processing to Download after you have passed the security check and clicked on Go to Download below the document preview box.
Check what error codes (if any) are stored in the camcorder and see if that helps to further isolate what the problem is. Go to p.17/130 (pdf page numbering) or Sect.1. Trouble Shooting to see where to find the codes in the menus and also what they mean.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had the same issue and it was the flex connector that connects the lens assembly to the rest of the camera. Because the assembly can move, and the edge of the chassis is quite sharp, the connector eventually breaks at the point where it passes through the lens assembly chassis. It starts off as an intermittent problem, but eventually becomes permanent
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Simon Marsh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 181
