メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
Is My new 250 Gb SSD compatible with My iMac?
Installed hardware with no issues. Unable to Erase (Format) the drive so I can’t install System. Removed SSD and connected via USB to MacBook Air (2014)…Formatted without issue. Reinstalled in iMac…saw it this time but would not install Backup and after that wouldn’t see it anymore. Is this a firmware issue?? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
What is the macOS release your MAcBook Air is running and what was the macOS release your 21.5" iMac is running.
You maybe hitting a firmware/OS file system issue as Sierra and older OS's used HFS+ and from High Sierra onward is now using APFS and the systems firmware needs to be updated to boot from an APFS drive.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Details: As shipped, these models only supported the 3 Gb/s SATA II standard for both a 3.5" hard drive and a 2.5" SSD. However, as first discoveredby  OWC, the iMac EFI Update 1.6, released two days later, quietly provided 6 Gb/s SATA III support.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Steve Biagioni さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 26
