メインコンテンツにスキップ
2020年5月に発売される13インチMacBook Proは、クアッドコアのインテル第8世代Core i5およびi7プロセッサー、インテルIris Plus 645統合グラフィックスを搭載しています。(モデルA2289/EMC3456、Thunderbolt 3ポート2基搭載)
79回答 すべてを表示
Any advice on removing the back cover of this machine,
I have tried multiple things including a suction cup, some old credit cards, my fingernails, and a stiff plastic straw, I ordered some actual pry tools to see, but I feel like I will still have issues, I have gotten a good amount of clips off but it is not a big enough gap the grab the button cover from the the trackpad area and pull forward
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The trick is to slide the bottom cover to the front and then lift.
I sometimes find junk has gotten into the grove area which stops it from sliding forward. I do two things I use strong duct tape to create a handle to pull forward on the front half of the cover and leave space in the center for a good suction cup to pull up and a second set of hands to hold the system. Then dripping some isopropyl alcohol along the left and right side gaps to help break the seal.
Update (06/03/2021)
13” model
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
So it seems for me what is stuck is the slide in tabs, I am unsure how to get them dislodged, I also noted that the model shown in the picture is a 16 inch, however I am almost 90% sure the 13 inch has the clips as well
さんによる
@gamerchapet - It's the same setup! Look at the added image
さんによる
@danj Ah so looking at that all I have it the two "Drop in Tabs" the rest is dislodged, but I have no idea how to get the drop in tabs to let go, so I can move the back cover off
さんによる
@gamerchapet - Slide and lift and slide a bit more. The middle drop in tabs need the lift.
さんによる
I manage to get it removed, now I am stuck on the part of putting it back, I am pretty sure it's just a matter of lining it up, just taking forever to line up. (Why did they move to this from the 2015 drop in design) *sigh
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Skylar さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 136
今までの合計 522
