メインコンテンツにスキップ
Repair and disassembly guides for Kenmore Microwaves.
182回答 すべてを表示
Switch replacement? Kenmore 80322 1.6 cu. ft. Over the Range Microwave
A year ago, three switches, as I recall, were replaced under extended warranty. Now those switches are wearing out again as evidence by poor and uneven heat. If it follows the same failure progression, this will eventually cause the circuit breaker to trip and the microwave will be "dead". As I understand it, the door switches must work properly to ensure microwaves do not escape the enclosure during use. I'd like to find the service manual so I can replace them myself as it appeared to be an easy fix at the time. Does anybody have a link to the service manual for this model? Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
While I don’t have a link to your manual, I did have one thought. When my parent’s GE microwave broke down last year, we couldn’t find a manual online so decided to just open the microwave to have a quick gander. When we did that, we actually found a full schematic and service diagram tucked away under the outer shield. I am not sure if Kenmore does a similar thing but it may be worth a look.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lynnd さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 232
