メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
How do I fix drift
My left analog keep drifting. Started off jut forward and now does it in all directions. Strange part is that even when I don’t touch it out of no where will start drifting forward around 15 seconds later.
I cant see a guide on here about replacing the hole joystick mechanism but only the caps.
Controller hasn’t even been used a massive amount. Been sat around doing nothing for most it’s life.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You can somehow unclip and bend out the potentiometer part of the joystick just enough to clean the insides. Replacing the joystick mechanism would require desoldering tools and temperature control, otherwise you’ll overheat the board and solder pads get torn off.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
CnPx さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 987
