メインコンテンツにスキップ
HuaweiのHonorモデル用の修理と解体ガイドです。
20回答 すべてを表示
Honor Play - Does not startup after severe Water damage
Hello guys,
somehow my phone (honor play) got into the washing machine. After that, it doesn’t turn on, nor charge - nor does it react in any way. Any suggestions, which part of it is most likely to cause the defect? Do you think ALL parts are broken? Or is it maybe just the battery? Or is the mainboard broken? Did anybody of you ever encountered a similar problem and got it fixed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
There are no waterproof ratings listed in the phone’s specifications so at best it may only be water resistant and not waterproof.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove any shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a teardown video for the phone that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair as they will have the necessary equipment e.g. ultrasonic bath used for cleaning electronics and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Johannes Herrmann さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 169
