メインコンテンツにスキップ
幼児用玩具の修理ガイドです。
974回答 すべてを表示
Fisher Price Bongo set not working (no sound or light - new batteries)
Fisher Price Bongo set - has joint for changing position of bongos. 3 new batteries have been installed and we checked the wiring in both bongos and nothing seems to be loose. A slight whrrrr then no sound or light.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
You could check the the battery terminals, make sure they aren’t corroded, if they are clean them. As for the slight whrrrr noise, this toy doesn’t have a motor only a speaker and lights. Now I think the whrrrr noise is from the speaker, it may sound like a low humming/static, meaning that the speaker could be burnt out, and needs replacing. Since you’ve checked both all the wiring making sure its not loose or has any slices in the wires it could be the joint switch not working right/making a connection to the circuit board for the toy to start up, check around there. You need to find out where the whrrrr noise is coming from, It could lead you to the problem and the solution.
I’m assuming you have this set: https://youtu.be/AskQ8nvYEHc
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This is new no corrosion or damage I can see
Yes I have the set
さんによる
コメントを追加
I have a fisher price drill a few months old not used much now that novelty is worn out and i tried to change the batteries it was stop & go
It still isn’t running
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Peggy Watters さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 37
今までの合計 1,236
