メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
20回答 すべてを表示
Water damage - are these components fried?
I was given a water damaged iPhone 6s and I took it apart (it has been dry for a long time) and followed the guide to fix water damage, took the logic board out and left it in 91% isopropyl for a night and took the stickers off the back emi shields and found what looks like some corrosion on the connectors, and I can’t find any schematics for the iPhone 6s logic board so I don’t know if it’s missing any components.
my question is are any components on this board obviously damaged or missing and does it look recoverable?
(I also should mention that I don’t care about the contents of the phone so if anybody has an iPhone 6s logic board they don’t need I’ll pay up to like $20 for it)
Edit: high quality image links
https://i.imgur.com/F2FCtfJ.jpg
https://i.imgur.com/Ai0o8sU.jpg
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント:
the stack of 6 cap on the right side of the second picture looks like it might be blown. try using a soldering brush and clean that cap up. it may need to be replaced. also in the second pic theres alot of corrosion in the top left side of the board picture.
さんによる
You need proper tools to repair liquid damage not just ipa and a brush. Since there is corrosion in that area there is likely damage under that baseband pmic.
さんによる
@logixal Thanks for your answer! Just wondering what's the stack of 6 cap mean what exactly is that? Also I got an old toothbrush and cleaned it and used it and alcohol to clean off the board, and put it back in, but the phone won't power on, so I am going to try to take off the EMI shields on the other side so I can see if theres damage under them.
さんによる
@tech_ni Thanks for your answer! yeah I figured it probably wouldn't work, but i may as well try lol
さんによる
@jacobgg45 the brown silver edged rectangle looking components on the board.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
dont use 91% find some 98% or higher. what you have isnt strong enough sadly. give 98% a try and that should kill a little more of the corrosion. or even better if you have an ultrasonic cleaner chuck it in that. look online for what u need to do for that. they are pretty cheap to get. but not really worth it for an iphone 6
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Doens't it say < 90 % on the ifixit guide for water damage? I don't think they sell 98 anywhere near me. Yeah ur right about the worth, I just figured I may as well try cuz it was a free phone
さんによる
コメントを追加
回答を追加する
Jacob Gerhart さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 77
