メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
276回答 すべてを表示
Very slow after trackpad install. Trackpad not working or clicking.
Dear all,
I replaced the battery on an A1708 macbook pro. Afterwards I figured out how I ruined the trackpad while removing the battery adhesive. At first I thought I only damaged the cable. But I scraped off smd components from the trackpad.
Because I suddenly had to order a new trackpad, I put everything together without the cable attached so at least you can work with it with an external keyboard and mouse.
When starting, everything is extremely slow when logging in. Vent is on 100%. Top bar remains transparent.
When I got the trackpad I installed everything the way it should be. I did not put everything completely together. I wanted to test it's function first. The trackpad mouse worked, keyboard worked. The mouse click however did not work. I removed the adhesive of the cable and stuck it to the battery. Put everything back together.
Now I hoped everything magically would turn normal. But alas.. the keyboard works but now the mouse does not work. Also macOS is still extremely slow to the point you cannot work with it.
What happened? And how can I fix it.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
This is the expected behavior! Your system is in CPU Safe Mode!
This is when your systems SMC lowers the CPU’s clocking and pushes the fans RPM so you don’t damage your logic board.
Once the touchpad is reconnected SMC will regain access to the sensors you disconnected.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Everything is connected properly now, yet trackpad is still unresponsive. And not 'clicking'.
Do I just turn on, login and let the macbook run for an hour hoping it will go out of safe mode?
Or as I read somewhere that resetting the SMC will fix these issues?
さんによる
@morteus - New unit? Yes SMC reset will be need. I would run the onboard diagnostics as you may have another problem as well.
さんによる
コメントを追加
回答を追加する
Pascal さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 12
今までの合計 209
