メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
Rear camera is blurry after housing
I replaced the housing on a customers iPhone x
1x is not focusing, 2x works fine, flash works
It was working fine before
I cleaned the camera lens and the glass, 3x the focus problem persists. I've ordered a camera replacement to see if that'll work. Will this affect face ID?
Also what may of caused the focus problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The FaceID is located within the front camera/speaker assembly so shouldn’t be affected by rear camera replacement. As for the camera itself, unfortunately, it does seem to maybe have sustained some damage during the repair to the autofocus module, although I’d suggest completely wiping the device to ensure no software issue is causing this (if the device belongs to a customer and you aren’t able to do this, try moving the camera into another compatible device that can be reset and tested), and if the problem persists after this, replace the rear camera entirely.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Che Hayden さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 169
