メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
276回答 すべてを表示
Purple flickering lines on screen
Hello
I have the following MacBook Pro model (MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports)// 2,3 GHz Intel Core i5// 8 GB 2133 MHz LPDDR3// Intel Iris Plus Graphics 655 1536 MB) and suddenly the screen started flickering with purple horizontal lines. The lines do not appear on an external monitor that is connected to the computer, they only appear on the Mac screen.
I have tried rebooting with the following options and it doesn’t work. Any ideas?
1) Option, Command, P, and R
2) Control, left Option (Alt), right Shift
3) Shift, left Control, left Option (Alt)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Due to the fact your only facing the issue on the MacBook screen itself, it would seem you have physical damage. It’s either gonna be the LCD cable, a board Issue or god forbid a damaged screen :(
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you for your prompt reply. I was wondering whether it is a known defect for this model, given some issues such as this one: https://support.apple.com/13-inch-macboo...
さんによる
The LCD cables are common to deteriorate over time that's why I mentioned this first :)
There certainly is a know backlight driver issue with most MacBooks, but as you see an image it would mean the backlight is fine.
I just hope for your bank's sake it's not the screen itself :(
さんによる
@eazy_pc_repairs - Older Unibody the cable was often the issue! The newer Retina systems its a bit different! Think how Analog TV worked with the rabbit ear antenna you had to move them about to get rid of the ghosting. Now with Digital you don't get ghosting at all! The signal works or it doesn't!
Same thing here! Between the older LVDS signaling and the newer iDP/eDP signaling the retina systems use.
さんによる
コメントを追加
Sadly, your internal display assembly will likely need to be replaced. These newer Mac’s tend to run hot and as Apple moved the T-CON board to be within the uppercase it tend to cook (pass me the BBQ sauce!)
Dust buildup in the fan blades and heatsink fins tend to be the largest issue. Using the system on ones bed or other cloth surface which blocked the air flow is another. Lastly, running the system hard without pushing the fans to the max using a good thermal monitoring app like TG Pro.
See if cleaning the dust out and pushing the fan helps. At least it can buy you some time. Here’s the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and the guide to put it in MacBook Pro 13インチ Touch Bar Late 2016のディスプレイアセンブリーの交換
MacBook Pro 13" Retina (Late 2016-2017) Display Assemblyの画像
製品
$454.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Myrto さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 27
今までの合計 2,884
