I broke the flex cable when opening the phone
at first the touch screen didnt work, then it the enteric screen went black, can I repair that part or do I have to replace the entire screen?
Hi,
Are you sure the flex cable is damaged ? If it is, then the flex cable can be repaired but needs professional tools and steady hands. Otherwise, it a new panel. Also dont throw the panel away as you need to copy the information from your old panel to the new one, so that true tone works.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 157
New screen needed.
daniel さんによる
