メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
How easy is a keyboard replacement?
I can’t see a guide on here for replacing the keyboard - not the whole top assembly with trackpad etc, but just the keyboard itself. How easy of a job is this? Replacement keyboards are only around £15 whereas a top case assembly is around £120, so of course I’d much rather buy the former, but I assume replacing just the keyboard is going to be a harder job than replacing the whole top case. Apologies if this has already been asked somewhere, haven’t been able to find anything though.
Not sure exactly what caused it, but my E key stopped working properly for a while, then the D started playing up, and now A and S do not work at all, so I’m having to use an external keyboard.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This is bit of a toss up!
Here’s a cheaper uppercase 15” Retina MacBook Pro, Top Case & UK Keyboard (12/E13), Apple P/N B661-6532 £62.52 which a lot cheaper than £120 you priced it at. The part I’ve listed is a recycled part not new.
Replacing the keyboard alone is a big job! And if you’re not careful you can damage the uppercase.
So while you save a bit of money replacing the keyboard alone it ends up costing you time, cuts and scrapes on your fingers and the risk of not having a working system in the end.
So consider your skills and the time as well as the value of the system to you.
MacBook Pro 15" 2015 Teardown & Keyboard Replacement which is a good reference on the task. Make sure you get the backlight and a ton! Of the needed screws. While Adamant IT didn’t fully populate the screws I often find the keyboard is mushy if you don’t fully fill them in.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Thanks for this! That is a much cheaper price, I see it’s sans-trackpad though - is this easy enough to navigate whilst preserving my original trackpad? I’ll be getting a friend to do the job and he does this kind of thing for a living, I just don’t want too hard a job for him. Like I say though, he’s done plenty of this kind of thing before. If I could give him an estimate of how long it would take him it would be sweet.
really appreciate the answer, in quick fashion too :)
さんによる
@supa42 - you'll need move it over from the old case to the new case follow this guide to take the battery out to then get to the trackpad MacBook Pro 15" Retina Display Mid 2012 のバッテリーの交換.
Often I find this series needs a new battery as well. I would recommend installing this app CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
さんによる
Thanks. So how long do you think the process would take all-in-all?
The battery indeed does need replacing, has done for quite a long time, but I'm on a tight budget at the moment (https://i.imgur.com/OgCAqa7.png)
さんによる
@supa42 - I don't think you have much of a choice here ;-{ You really need both. Getting the old battery out is a bit of a chore. Maybe it would be better (and cheaper) to just get the full uppercase with battery & trackpad already installed, the part (FRU) Apple would have used if you had that as an option.
さんによる
Ah that's a shame. After having a quick look I see that's around £300. Considering how old the machine is already, it doesn't seem worth it. To be honest I'll probably just continue using an external keyboard.
Many thanks for your help anyway!
さんによる
コメントを追加
回答を追加する
Scott Fenner さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 210
