メインコンテンツにスキップ
Nest Cam Outdoor has died - no power light at all
Anyone tried repairing one of these?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント:
Hi @reticentrobot ,
have you checked that there is power getting to the camera, you didn't say? Either the power supply or at the power supply wiring at the camera itself?
さんによる
@jayeff Not yet, I’ll see if I can figure that out this weekend when I pull it down. I put it through the wall and caulked in the hole, so should be interesting getting it back down to mess with.
Before it finally kicked the bucket it would constantly go offline, and I’d have to unplug it for a few minutes and plug it back in to get it going again. It finally just would no longer reconnect and that’s when I noticed it didn’t even have a power light anymore. I checked the power connection from the camera to the section where it connects to the power cable and that all seemed good, so I’m at the point of having to take it down and figure out if there’s anything to be done or if I have to just replace it. At $200 a pop I’m hoping some sort of repair can be done.
さんによる
@jayeff I can confirm that I'm getting power up to the USB female (wall outlet to USB power supply), not sure how to test any further than that. There's also no obvious way to disassemble the camera housing that I see, appears to be glued together.
Found someone who has done it here: https://www.youtube.com/watch?v=iQY4hHRP... - unfortunately I'm about to have a surgery and will lose the use of my left arm for a few weeks, but after I recover from that I'll take it apart and see if I can see anything that jumps out at me as the issue.
さんによる
コメントを追加
1 件の回答
I have the same problem and since it was out of warranty, I figured why not try to take it apart. I think it's because there is water in the camera.
I was able to take it apart, and also may have figured out where it leaked from. We had a ton of rain over a matter of a week, and this is when the cameras either failed or had condensation on the lenses. I have 2 cameras out of a dozen or so that failed and they were the ONLY ones that were mounted upside down (where the image was rotated). The only place any water could settle and seep into the camera is through the speaker holes, which are facing up. So I figured that is where the water was coming in.
So moving forward, if the camera is mounted upside down, I would recommend to seal the speaker holes with silicon or duct tape. (the speakers are pretty worthless anyways).
Now the teardown:
  1. On the face of the camera I took a sharp utility knife where the black face meets the white edge. Once I got underneath it in 1 spot, walk the edge of the knife all the way around the circular face slowly. This will loosen the foam tape that is holding down the face to the body. Make sure to get all the way around the round face and then pry it off.
  2. To prepare it for reassembly, I cleaned up the foam seal that was holding down the black face. I did this on the body and the glass as much as possible using a flat screw driver or pin.
  1. The glass that covers the lens may be loose and that is also where the water may have gotten in. (Mine was loose and came right off). I will use a small amount of clear silicon to seal it up at reassembly.
  2. Once you get the face off you will see 4 holes with Philips screws. Remove these 4 screws using a long micro screw driver. Keep these safe as they have a red grommet to seal them in.
  3. The white exterior housing holds the clear housing. The clear housing has a blue rubber seal that locks it to the white housing. So the next step is to separate them. Once you see the blue rubber seal all the way around, it should come apart easily.
  1. Once you get the 4 screws out, gently stick the screw driver into the same holes and gently try to loosen the WHITE housing from the clear unit. Use the screwdriver and wedge it into the hole and lean towards the center of the camera. Try this on each hole and hope that one of them pops the unit loose. If not, you can also use a utility knife to get in between the white housing and the clear unit. Once you get one side loose go around the whole unit to pop out the clear unit.
  2. Now that they are apart, drain the water (Mine had about a teaspoon of water in it). You do not have to disconnect anything, but you may want to for repairing something. If so disconnect the wires that are attached to the white housing. The one with 4 wires is a bit tough to remove, be very careful to not break the wires.
  1. I then let the pieces sit out in the sun for a day or 2. You can also stick the camera in a box and let sit INDIRECTLY with a blow dryer on low heat air dry them for about an hour or so. DO NOT USE RICE as it will get stuck inside the camera housing and inside the camera itself.
  2. I was lucky enough to be able to test it after drying and it worked great. Though the 2nd had a broken pin where the 4 wire connecter is on the camera motherboard.
  3. To reassemble, make sure the screw holes line up and reverse the process
  4. In order to seal it up again, I used a pin/toothpick to apply clear silicon to the edge of the clear unit and where the foam tape was and also around the Microphone and light holes that are on the face. I also used the same clear silicon to fill the holes in the speaker. which is where I think the water got in.
    Good Luck
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @rpsf,
Great work.
How about you create a repair guide and have it posted on ifixit so that others can more easily find it. No doubt they'll thank you for doing so.
Most guides on ifixit are created by users
Also just a point - if you fill the speaker holes with silicone, how's the audio from the speaker going to be heard clearly and not muffled or perhaps maybe not at all if the holes are blocked?
Moderator
さんによる
コメントを追加
回答を追加する
ReticentRobot さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 33
今までの合計 349
