メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Digital Output - Headphone Workaround
How do I get the Headphone/Digital Output to play analog? Is there a driver one can download or a cable that could convert this digital signal to analog? Not sure how that works specifically. And I don’t want to waste time and money on accessories that won’t solve the problem.
The speakers and everything works just fine and there is no issue with the headphone jack being stuck. That seems to be the only thing I can find when I search for resolutions, and I just want to say that isn’t the issue. I have bluetooth headphones, but there is a lag with the older bluetooth tech. Working in audio editing, this can be frustrating. Thank you very much!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Your headphone jack is dual use! You can use a standard analog mini plug headphone or connection to a wired speaker.
You can also use a digital TOSlink to Mini TOSlink Digital Optical S/PDIF Audio Cable like this one:
So depending on what your needs are analog or digital use the correct cable.
Update (04/19/2021)
@AJ Cronk - There's no drivers needed. The macOS has what’s needed.
Sadly, it sounds like your jack is damaged. There’s a lot going in inside the jack! The analog contacts are also switches so the audio is sent to the speakers or to the headphones as you can see here.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello! Thank you for the quick answer. Unfortunately, when I plug regular headphones in, the control only says “digital output” and there is no sound to my headphones. Is there a driver missing that I need to install?
さんによる
コメントを追加
回答を追加する
AJ Cronk さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
