メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Why I have thick vertical bar suddenly appear on my display?
Suddenly out of know where I have a thick dark vertical bar showing on my retina display. Anybody else have this kind of problem?
And sometimes inside the bar, it retains a few of my previous images (like LCD shadow/ghosting)
But in the middle of the bar every image I put in there, left a ghosting/shadowing mark on it, it was like this in video: MacBook Pro Retina Early 2015 display has blur horizontal thick line & shadowing problem
Any fix for it? Except changing the whole display assembly of course.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Try disconnecting the display cable, inspecting the pins both on the cable side and the port side for damage, dusting them with compressed air, then carefully reseat the cable. If that doesn’t help, you can try replacing the cable itself (cheaper than replacing the display). In my experience though, this specific visual glitch is normally due to damage to the display assembly itself and not an issue with the display cable. It may also be worth checking with an external monitor to verify the issue is not with the graphics, but rather the hardware of the display. My best guess is that the display assembly itself is damaged and would need to be replaced.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yes its a T-CON issue within the display ;-{
さんによる
bad luck ? i just bought this from a friend and use it for about 3 days, changing the whole display assembly would cost as much as the macbook itself
さんによる
コメントを追加
回答を追加する
Aaron さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 186
