メインコンテンツにスキップ
2017年4月に発売されたSamsungの新しいフラグシップのスマートフォン、Galaxy S8です。
304回答 すべてを表示
Battery health is still show less after new battery replacement
If you see the screenshot that indicate that battery health is 83% after replacement of brand new replacement battery. Is that poor new battery or something else? How we can make 100% battery health ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント
Is the replacement battery a genuine replacement part from Samsung or a third party?
さんによる
It is Third party not original one.
さんによる
@irepairman If the rest of your device is functioning fine, then you may have just received a bad battery unfortunately. Are you able to try another battery in the device, preferably a new Samsung battery?
さんによる
I put new battery but still it shows weak
さんによる
I have the same issue with s10e I have tried 3 new batteries so far. Still I hav the issue .... any ideas
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
This is because the battery cycle count has not been reset. In order to reset it, you either have to root your phone or have an authorized repair center like UBreakIFix to do it, which they charge $50~ to do so.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
When you replaced it did you allow the battery to cycle fully a few times? Charge to full, discharge completely, then charge again. Do this a few times. When it dies, turn it on again and let die again. Do this until it fails to turn on (screen should just show battery is at 0%) once it does charge to fill, and let die again. When replacing lithium batteries from what I've experienced you have to cycle the battery to get it fully functional. Otherwise could be a bad battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Samsung think it will be better for them to make step against right to repair even when customer buy original OEM battery, do we really own our phones ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
iRepairMan さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 15
過去 30 日: 65
今までの合計 2,664
