Repair guides and support for the first generation Town Car, a full-size luxury sedan manufactured by Lincoln.
shawn @shawn88
評価: 1
投稿日: 2021年4月10日
i changed my plugs cause i had a misfire an when doing so had a lot of oil on my plugs an coil packs 2007 town car 4.6
この質問は役に立ちましたか?
brandon k @brandon_k
評価: 3千
7
6
5
投稿日: 2021年4月11日
Sounds like you might need a new valve cover gasket. Check to make sure valve cover isn't cracked. If it isn't then the gasket is most likely the culprit.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 171
