The screen is flickering badly when the lid is in certain positions
The screen is flickering badly when the lid is in opened in certain positions or moved slightly
Hello Betsy…Most likely the flatwire cable that connects to motherboard from screen has a break or breaks in it . Screen replace is done if so . there is a SMALL chance that connector has worked a little loose on motherboard . If you were to follow a teardown/disassemble video you can try re-seating connector . Don’t use extreme force , there is usually a gentle click if was loose .
Good luck
Hugh
このアンサーは役に立ちましたか?
Hi Hugh, thanks for helping. I've had a look at the video (..panic). I had thought (hoped) that maybe cable was getting pinched. A whole screen replace sounds huge. Do you know what the right part number would be for a ASUS VivoBook S200E-CT216H model please?
Thanks again
Betsy
Hiya Betsy...Pardon delay , slammed with chores . I looked up that screen on 'Laptopscreen.com' and I see that the flex cable is not included . They have no stock on matte screen but have glossy at $cdn 76.79 . NOT likely to solve problem with out that cable unless cable slightly dislodged . You have a touch screen . The digitizer is a separate item that can be ordered if it is bad (NOT likely) .
Unless it was dropped to your knowledge the screen may be a waste of money . It would be nice to have it on the bench to confirm . I would search for a disassembly video and check it out yourself , cant hurt much since it is not working .
Ebay may have flex cable . I have contacted Asus Canada before , they may have a part for you .
Luck , Hugh
PS...ASUS VIVOBOOK S200E-CT SERIES is the only part number I can see on their site ...cheers
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 75
