メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
275回答 すべてを表示
Early 2013 MacBook 15" Retina display hinge replacement
Hi All,
I am trying to replace both broken hinges on my Early 2013 Macbook 15” Retina. I have all the necessary parts in hand and have separated the display from the body successfully. Now, however, I have hit a snag: I can find no disassembly instructions for removing and replacing what I believe must be the WiFi wire. Any links and/or tips? Thanks for any help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sorry we don’t have a guide, all we have is this MacBook Pro Retina Display Teardown for reference.
このアンサーは役に立ちましたか?
スコア 1
15 件のコメント:
Thanks! I only hope this doesn’t mean I have to tear the display apart to replace wires...
さんによる
Yep! You do ;-{
The better direction is just replace the entire lid assembly 15" MacBook Pro Retina Display Assembly, Apple P/N 661-7171
さんによる
Sadly, I fear you are correct. All for a 1/4" Retina connector that won't go through a lid hinge. Shame on Apple. And any display disassembly looks doomed to disaster. However, here's what I think I will do (less than optimal, but reasonable): I will try to untangle and keep the old Retina wire as well as the new replacement one. I might be able to adhere them adjacent to the laptop lid without cutting them. No more onboard camera, but everything else will work. If there only was such a thing as a male-to-male Retina plug adapter...
さんによる
@dschind - As much as I would like to tell you that would work, it won't! The camera cable also carries a voltage and thermal sensor which if you disconnect will cause your systems SMC to throttle the CPU and ramp up the fan.
さんによる
Thank you so much for your contribution! This has given rise to one other (maybe crazy) thought. What if I can succeed at prying apart the hinges themselves enough to swap new-for-old? Then I can leave the cabling untouched and functional. Very tricky at best, but...
さんによる
10件以上のコメントを表示
コメントを追加
回答を追加する
dschind さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 25
今までの合計 390
