メインコンテンツにスキップ
2018年9月21日発売。モデル番号A1921, A2103, A2104、GSM もしくはCDMA / eSIM もしくはナノSIM /64, 256,もしくは512 GB/ シルバー、ゴールド、スペースグレイ(正しい発音は"iPhone 10 S Max")
381回答 すべてを表示
Replacement XS Max screen won’t fit. Why?
I’ve an iPhone XS Max with a busted screen. I ordered a replacement but the screen won’t fit. It has these little tabs sticking out all down right hand side but existing screen doesn’t so there’s nowhere for these tabs to slot into.
Can anyone tell me why or how to get around this please?
thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Your tabs are stuck in the phone, you have only lift up setje front of the screen and the metal frame of the screen is still inside the iPhone. You first got to get them out before you can instal your new screen.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
You’re absolutely right! Problem solved and new screen installed. Thankyou ??
さんによる
How do you take the tabs out?
さんによる
コメントを追加
have you ever had your screen replaced by a shop or anything?
in the guides ive seen all the replacement screens have the tabs… thats how it holds to the body of the phone.
iPhone XS Max スクリーンの交換
follow that guide and see if you can get it reattached that way.
Update (03/31/2021)
heres a few more tips for getting this thing reattached
https://www.iparts-4u.co.uk/blog/iphone-...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
No never had screen changed. Bought phone from cash converters when it was 6 months old. It was in new condition.
It’s really odd that the replacement screens won’t fit. I’ve run the serial number through Apple and it all checks out ok so I’m baffled?
さんによる
@dragon2273 only thing i can really suggest is either the phone is a REALLY good counterfeit OR there is something jammed in some of the slots where the "pins" on the screen would fit? maybe use a magnifying glass and check to see if theres gunk or something in there?
さんによる
Merci de votre réponse
si je comprends bien il faut enlever la plaque lisse qui entoure le téléphone pour retrouver les ancrages ?
je ne veux pas faire bétises
さんによる
コメントを追加
回答を追加する
dragon2273 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 35
今までの合計 1,710
