メインコンテンツにスキップ
Retina MacBook 2016からアップデートされたバージョンです。モデル番号はA1534(EMC3099)です。Turbo Boost使用時最大3.6GHzの最大1.4GHz Core i7の高速Kaby Lakeプロセッサ、最大50%高速のSSDを搭載し、最大2倍のメモリをサポートしています。
82回答 すべてを表示
I used my computer last night, now it won’t turn on or charge up.
I just used my macbook last night to do homework then watch youtube. I left it plugged up when I went to bed. This evening it won’t turn on or charge up. I’m not sure what is wrong with it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Here are some things you can try: 1) With the charger plugged in, press and hold the power button for about 10 seconds. Then press the power button again. If the machine still does not power on, move onto the next step 2) Attempt to reset the SMC. After resetting the SMC, attempt to power on. If you still aren’t able to power on, move onto the next step 3) Try using a separate known-good charger. If you don’t have access to a charger you can take it to a tech shop and ask them if they can try to charge it as a free service. If it charges using a separate charger there may be an issue with your charger and it might need to be replaced. If none of these steps work for you there may be a hardware issue with your machine. If that’s the case I would recommend having it diagnosed by a Mac repair shop. If you’re feeling adventurous you can try disconnecting and reconnecting the battery, but be forewarned that these models can be a little tricky to open safely. Here’s a guide for accessing the battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lexie Savannah さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 13
今までの合計 54
