メインコンテンツにスキップ
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
468回答 すべてを表示
iPhone XR screen unresponsive to touch?
Today I was able to replace the charging port of my XR. Taking things apart to replace and putting it back together went smoothly until I attached the flex cables of the screen that is all original / the same screen that came with the iphone.
Before putting the screen back into the housing, I tested to see that everything was working and on after boot, everything except for response to touch.
I reattached the flex cables of the screen in case it was misaligned, especially the one that is for touch response several times more. After that didn’t work, I checked the pins visually to see if there were any signs of wear. There may be damage in resistance within the pins, but as of now it’s hard to confirm without a proper multimeter. I’ll have to get new probes to test.
I’ve repaired my phone where the screen needs to be taken off before and all went well. And whenever I disconnect a flex cable, I would always use a flat spudger and carefully use the spudger again or my finger when it’s time to reconnect.
Do you think I should find another XR screen and test to see if it’s just the one I have right now that’s unresponsive?
What do you think the problem may be and what are the solutions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I will recommend you buy a new screen then something happened to me when I replaced my iPhone Screen because if you bend the flex cables more than 90 degrees. But before you buy a new screen, reset the Phone and see if that helps.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi Keshawn, thanks for taking the time to give your valuable input. I didn't think the bending in the flex cables would be that delicate but that is very much a possibility. As for resetting the phone, it's good practice to backup your data before attempting any internal repairs. Glad I did just that. I'll see if resetting the phone will help solve the touch issue before finding a replacement and will report back the results. Thanks Keshawn!
さんによる
Hi Keshawn. I'm here to say the touch is now fixed after getting a replacement. Unfortunately, resetting didn't work, which means the screen is in need of replacing. Chances are I might've shorted the screen by accident when working on the repair or overbent the flex cables like you said. Nonetheless, thank you for helping me fix the screen. I can use my phone as normal again :)
さんによる
Thanks For the Replay makes. My day
さんによる
コメントを追加
回答を追加する
Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 23
過去 30 日: 78
今までの合計 1,332
