iPhone XR screen unresponsive to touch?
Today I was able to replace the charging port of my XR. Taking things apart to replace and putting it back together went smoothly until I attached the flex cables of the screen that is all original / the same screen that came with the iphone.
Before putting the screen back into the housing, I tested to see that everything was working and on after boot, everything except for response to touch.
I reattached the flex cables of the screen in case it was misaligned, especially the one that is for touch response several times more. After that didn’t work, I checked the pins visually to see if there were any signs of wear. There may be damage in resistance within the pins, but as of now it’s hard to confirm without a proper multimeter. I’ll have to get new probes to test.
I’ve repaired my phone where the screen needs to be taken off before and all went well. And whenever I disconnect a flex cable, I would always use a flat spudger and carefully use the spudger again or my finger when it’s time to reconnect.
Do you think I should find another XR screen and test to see if it’s just the one I have right now that’s unresponsive?
What do you think the problem may be and what are the solutions?
この質問は役に立ちましたか?
