メインコンテンツにスキップ
Lenovo ThinkPad T480のサポートと修理ガイド。2018年1月発売
Markings on battery, T480, problematic?
Hi guys,
I bought a secondhand T480 at a reasonable price. It had a slightly weird smell, and opening it, I wonder if it had some wine spills or similar. Anyways, most looks good inside, but there are these two strange ‘sparkle’-markings on the battery that do not come off. I’m unsure if these are a problem or just a curiosity, any opinions? (there are two of these, alongside the battery, picture shows one of them)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Machine works great btw, more if it's a potential issue.
さんによる
コメントを追加
2件の回答
ベストアンサー
Ok, I will answer this myself.
Finally got through to Lenovo tech support, and the second guy was able to figure out there was no battery. duh.
So that just - and possibly literally - a dummy cover :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Hi @opux ,
It certainly looks like a “splash” mark but it makes you wonder how that would happen if the laptop was closed and something was spilled on it without affecting something else.
You would think that it would seep in and run. It looks more like the battery was exposed and then spilled on.
Are the marks just dis-colouration on the surface or are they “grooves” at all (bit hard to see in image) as if the battery case has been slightly eaten away by something acidic before being wiped off?
Is the battery hot to the touch when the laptop is charging or operating?
To me leaking lithium batteries smell like fruit mixed with a paint solvent (best as I can describe) but if it is hot then there would be hot plastic smells as well etc.
Since you say that everything looks clean and I hope dry, then create a Win 10 battery report, and check the Design capacity value against the Full Charge capacity value to determine the condition of the battery.
このアンサーは役に立ちましたか?
スコア 2
14 件のコメント:
There are two identical marks, so splash just doesn't seem likely. My main concern is if it's a sign something bad is happening from inside the battery. It's not grooves or etched. And doesn't come off with alcohol.
さんによる
The smell of the computer to me is mostly like butyric acid - the faint smell of puke. (possibly red wine)
さんによる
@opux
Did you create a battery report as I suggested, you didn't say?
Is it the original battery?
Here's a link to the parts for your laptop. (I think that you must have either a 20L7 or 20L8 model).
Click on Select Commodity > Rechargeable Batteries and Internal (3) to find the part numbers for all the compatible batteries for the model. It may be printed somewhere on the battery that you have already. If not it may be a cheaper compatible replacement.
If it concerns you and you wish to replace it, search online using the battery part number "only" in the search box of your browser, to find suppliers that suit you best.
さんによる
It doesn't have a harddrive right now, so no. I'm not expecting anything to be off in terms of functionality though. But who knows
さんによる
@opux
FYI Please check my comment above as I was I editing it and didn't notice your comment.
Cheers
さんによる
9件以上のコメントを表示
コメントを追加
回答を追加する
Opti さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 518
