メインコンテンツにスキップ
2020年11月に発売される13インチMacBook Airは、AppleのArmベースのM1 SoCを搭載し、8コアのCPUと最大8コアのGPUを搭載しています。(モデルA2337 / EMC 3598、Thunderbolt 3ポートを2つ搭載)
20回答 すべてを表示
Is the lid too tight?
Has anyone had slight difficulty opening their lid? I’ve noticed that i have to do it with two hands—one on the base of the MBA and one opening the lid. Just seems a like a couple of screws are a little too tight or something. When i use one hand, the front kicks up slightly. Not a major issue at all, just a minor annoyance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Its actually not a defect i own a macbook air personally and it is just 10 days old when i noticed that the bottom lifts up when i try to open from 1 hand i was scared but i spoke with the technicians at the apple store and they said its tight because its brand new and it will adjust and loosen up over 1 or 2 weeks depending on howmuch u use the lid so i started using it frequemtly and within 5 days the lid was smoother than ever it easily opens with 1 hadn and it isnt loos like cheap loos it stays at whatever angle so its completely. fine
さんによる
Thanks bro u saves me from lots of trouble
さんによる
コメントを追加
2件の回答
ベストアンサー
Surprisingly! The newer Retina MacBook Airs are so light you do indeed need two hands to open or use your finger to wedge the lid up enough to break the magnetic seal.
Apple didn’t alter the design between the Intel CPU models to the Apple M1
I’ve found the 2018 and newer are all difficult to open with one hand.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Macbooks usually have that one hand opening I think. So your hinges could be binding and need replaced. Or they have come loose, the screws could be slightly stripped but if your comfortable enough opening it up remove the screws keeping track of where they go, remove the frame around the screen and first off check every screw connecting the hinges to the top and bottom and make sure they're tight with no play at all. Then there should be a screw goin through the middle connecting the top and bottom of the hinges together. It'll have washers, spring, etc and usually is a hex head or different type of screw head then the rest. Take a fine tip marker first and draw a small line from right to left across the head of the screw and the washers etc after it. This is your reference line so you can always start over. Loosen the screw very little at a time until it opens smoother. You should not have to fully rotate these screws even half way around. Very little goes a long way. This is from my experience with laptops in general, not macbooks so I hope it's similar. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anthony Hasapis さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 95
今までの合計 8,517
