メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
64回答 すべてを表示
Hard drive beeps for a few seconds, then loud click.
My Dell laptop has been working fine for years, but recently there is a beep for a few seconds and then a loud click. It comes from the location of the Hard Disk Drive. The laptop is still running during and after the noise, so should I be concerned? Is this a problem that might corrupt files, or is the hard drive going to die soon?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
You should be very concerned! The click is the sound of the beginning of the end for your hard drive. Replace it immediately with an SSD (sold state drive). It will make the computer faster than it ever has been.
Simple to replace on this model:
Dell Inspiron 1545 Hard Drive Replacement
You will need to either back up or copy the old drive. Some SSD brands come with cloning software . For example, Samsung has “Data Migration” which is free from their web site.
The solution I would personalally use is to buy the SSD and an external USB drive case. Some are plastic, metal and water proof with a simple latched lid that just allows you to “snap” the drive into place.
Remember to remove battery BEFORE doing anything!
Dell Inspiron 1545 Battery Replacement
Take the old drive out, put the old drive in to the external case, install new SSD in laptop and replace battery.
Now boot up from the USB (old) drive. To do so - turn off the laptop, turn it back on, and start tapping F12 key before the Dell logo screen appears to bring up the Boot Menu and select the USB drive and boot up.
Install the cloning software and clone to old drive to the new SSD , shut down, disconnect USB drive and turn the laptop back on. You should boot up perfectly and more quickly into Windows. If you haven’t already done so do an inplace upgrade (keeps data and most programs) to Windows 10 - still free for Windows 7 and above.
While you are at it upgrade RAM (2 x4GB for maximum 8GB total). Also very easy to do on this model:
Dell Inspiron 1545 RAM Replacement
Let us know how it goes.
Dell Inspiron 1545 Batteryの画像
ガイド
難易度:
とても簡単
1 minute
Dell Inspiron 1545 RAMの画像
ガイド
難易度:
中レベル
5 minutes
Dell Inspiron 1545 Hard Driveの画像
ガイド
難易度:
簡単
3 - 10 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Check the SMART data, if it shows your HDD is a mess, replace it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Maxwell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 91
