メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook air does not have startup disc, boots to? folder.
I have a Macbook Air 2010 11” that boots to a ? folder all the time. I did all the normal things to try to come to a solution and all have failed. Reset smc, Pram, even booted into an external drive and ran disc utilities and found that the internal drive is seen, but there is no start up disc. So I played around a bit with the logic board and found all circuits from the Sata sector of the MCP to the SSD were ok. I even checked the PCI circuitry and all is good there. The one thing I noticed is that the MCP area on the board is getting very hot to touch 145 degree F, as compared to a known good board which is 125 degrees F. Could this be a bad MCP? Any thoughts would help? Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
To start with the blinking Question mark is the system looking for the drive to load the OS.
So do you have either a mounted drive internally or an externally? Is it running the OS version this system supports. I would use a macOS Sierra (10.12.x) bootable drive as using High Sierra (10.13.x). The highest this system can support (High Sierra) may not work as the systems firmware may not be able to work with the newer APFS file system.
Using the Option (⌥) key you should be able to select the external drive using the Startup manager.
Reference: Mac startup key combinations
I’m not sure I understand your TLA MCP term. Its best not to use your own TLA/FLA’s as most people won’t know what you mean technically there is no Multi-Chip Package on this logic board. If you are referring to the CPU or GPU chips just call them out. I’m guessing your CPU is running hot as its stuck in a loop looking for that boot drive.
Update (02/24/2021)
Ah! You have a mismatch issue! El Capitan is HFS/HFS+ based, High Sierra and newer are APFS based.
  • Your systems firmware was upgraded during the macOS High Sierra install to support APFS volumes, so its having issues with the older HFS/HFS+ drive.
And/Or the SSD you installed is a AHCI/NVMe drive instead of a mSATA which your system requires.
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
Dan thanks for your help! However, I am able to use a external bootable Mac OS El Capitan to work. But then from there I use disc utility to try to see if the internal drive is there and it is, but when I try to see if there is a “ start up drive” nothing shows up! Also, the ssd I’am using works fine in another MacBook Air 2010!
さんによる
Dan thanks again for the info. But please answer why the same SSD works fine in another 2010 Mac air?
さんによる
@Roger - Without seeing it directly I can only tell you the two likely possibilities as I've listed. The other two would be not having the drive set as the boot disk or the drive is encrypted so it won't work on another system.
Lets give this a try Restart your system and press the Option (⌥) key to enter into the Startup Manager then manually select your drive. Did that work?
さんによる
Dan
When I start up while holding "options Key" all I get is a wifi icon and a blank bar no drive or globe to select anything! However, it will let me enter my password for my wifi but nothing happens after that!
さんによる
@Roger - The drive is not workable! You are working off of the systems firmware services. Either the drive is bad or is missing the OS. Unlike the newer models your system doesn't offer internet recovery. What you enabled is a feature for remote boot from a server which has a shared image of the OS a bunch of systems share over a network, which is why your system stalled out.
At this point you need to use another mac system to create a bootable external drive (USB Thumb drive or USB HDD/SSD)
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Roger さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 405
