メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
327回答 すべてを表示
Replacement battery from ifixit isn’t working
I installed my new replacement battery but it doesn’t seem to charge. The system report says that it recognises the battery but it shows that it doesn’t charge and needs servicing.
I opened up coconut battery and it also says that the battery itself is older than my macbook and that it is in poor condition. The battery is also charging with 0 watts.
I didn’t have any of these issues with my old battery which was actually still in good condition. Although it had a high cycle count the system didn’t say it needed replacing but I decided to do so anyway as the battery was discharging within 1.5 hours of use. Did I receive a defective battery from ifixit?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Check your battery board data cable connection and for any damage MacBook Pro 15" Touch Bar 2017 バッテリーの交換 Step 10
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
Hi, that was one of the first things I did and it looks fine. None of the gold points are damaged. It might just be the case that the battery I’ve been sent is 5 years old and defective.
さんによる
@cooldude227 - Sure its possible! But the fact CoconutBattery is showing us the charger is connected just not charging, that's the charging logic within your system thats more likely suspect.
Are you using an Apple Charger and the cable that came with it? Apple did have a recall on the cable are you using the newer one?
さんによる
@danj Didn’t the recall only apply to the 2015/2016 version? I’m still using the original Apple cable that it came with. Also, my old battery didn’t have any issues with charging. The coconut battery app is showing that the new battery is in poor condition.
I’m going to reconnect the old battery and see if I have any luck tomorrow. Hopefully I didn’t damage the logic board or battery connector port.
さんによる
@cooldude227 - Think of it this way your car won't start what is the failure? Could be the lack of gas or it could be the fuel filter is clogged.
So you replace the fuel tank but the little bit of gas you had in the new tank is all you are seeing. So you assume the tank is bad. Not the fact the fuel filter is messed up.
Somehow we need to breakdown the problem so isolate what is failing.
さんによる
I've put my old battery back in and it works just fine, Im getting another replacement battery from ifixit soon so I'll test that out and see if I have any luck.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Cooldude2222 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 423
