メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
bottom RAM slot MBP 2012 13" gets very hot; shuts down at 95 degrees
I upgraded memory to 16 Gb and 512Gb SSD. I have cleaned laptop thoroughly, so no residual dust. Laptop sensor shows temperature rapidly rising when using any browser or video, shuts down at 95 deg. C. If only 8Gb in Slot 0, the temp gets to about 82 deg. C. medium usage; if in Slot 1 only, temp climbs to about 90-92 deg. C. I would really like to use 16 Gb since I run W10 in a virtual machine also. When both slots filled, temp hits 93 deg. rapidly. Is there anything I can do?
Update (02/20/2021)
i don’t know how to post the image better than this.
Update (02/20/2021)
I wasn’t expecting such a quick response. Thank you all.
@lemerise. I thank you for pointing out the pad over the ram slot. it isn’t there on this laptop. But your advice is well taken. I will simply use 8Gb. I had thought of putting thermal paste just below Slot 1 (where I think the pad was), but on second thoughts, I will make do with 8Gb RAM. Thank you for your assistance.
@Dan. TG Pro is paid software, I found. In any case, I have decided to settle for 8Gb RAM. Thank you.
Regards. Oladim
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Install this great app TG Pro please post a screenshot so we can see all of the sensors (you'll likely need to resize the window to get them all in one snap iFixitでの質問に画像を追加する方法
さんによる
@oladim - The tryout/test version is all you need! To post us a view on what's happening.
さんによる
コメントを追加
2件の回答
There's a documented ram slot issue on the MBP 13" 2012. The lower slot often fails. If you check inside your back panel you'll see that Apple installed a pad over the ram slot to compress it. If your MBP works normally only using the upper slot then install a 8gb ram stick in it and use it as is. Other option is to replace the logic board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This looks like a bad SO-DIMM not a slot issue. Are you using a matched set of modules? Also who’s did you use, do you have the specs for them?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, they are a matched pair. It doesn’t matter which one is in the slot; the behaviour is the same. On another MBP, they work without any issues. When I use either of them alone (i.e. 8 Gb) in slot 0, the laptop works well, and doesn’t shut down (the temp is still high - 78 deg. C). I should mention that I live in the tropics where the ambient temp now varies between 28-34 deg. C. I think I will go with @lemerise’s suggestion just to use slot 0 only. Thanks all the same. Regards
さんによる
コメントを追加
回答を追加する
oladim さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 174
