メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
薄型・軽量でスタイリッシュなSwift 3は、外出先での作業に最適なノートパソコンです。最新のNVIDIA® GPU、Intel® CPUを搭載し、バッテリー駆動時間が長く、ディスプレイは2種類から選べます。13.5インチ 3:2比率の2256x1504 IPS VertiViewディスプレイを備えたエレガントなシルバーの筐体、または鮮やかな色彩の14インチ 16:9 FHD IPSディスプレイから選択可能です。
My laptop won't charge
Hey, so my laptop has stopped charging after 3 years. I tried a different power cable but that's all. The problem could be anywhere form the power pack down. I've never had any issues like this before so I have no idea what it could be. Should I try to fix it myself?
Don't really want to spend 200 euro to repair something that cost me 800
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
At least try to open it up and see if you find anything obvious (burnt components, water damage, etc...) Maybe post some photos of the motherboard...
さんによる
Hi,
What is the model number of the laptop?
さんによる
コメントを追加
3件の回答
Check the AC adapter brick and verify that any removable cords are fully inserted. Make sure the battery is properly seated in its compartment, and that there is nothing wrong with either the battery or laptop contact points.
There are also some basic troubleshooting steps you can follow.
Otherwise remove the battery completely from the laptop and try running the laptop using the AC adapter. If you can use the computer for a couple of hours without problems, the adapter is obviously okay. Clean the battery contacts. Replace the battery and try charging it again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check the connector and the jack.
If the pins are no longer sticking out enough to “grip” when inserted - (maybe) all you need to do is bend them a bit so they provide the holding power they used to - when everything was new.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It's probably the charger l bought a charger off ebay for my laptop and I thought the laptop was broke but it wasnt broke something was wrong with my charger.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
danielforbes1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 24
今までの合計 6,194
