メインコンテンツにスキップ
Surface Pro 4の後継モデルとして2017年6月発売。別名Microsoft Surface Pro 12.3インチとも呼ばれます。モデル番号はFJT-00001。
51回答 すべてを表示
Refuses to boot from windows install USB but boots linux USB fine
Hey, I bought a surface pro 5 from a recycler. Turned out to work fine but was password locked. I wiped the drive in linux while testing (booted from usb), but when I went to re-install windows 10 it refuses to boot from the installer. I’ve tried 8 and 10. For 10 I used Microsoft’s media creation tool. Secure boot is off and enable usb boot is on. Any ideas? It just boots back to the bios every time I try
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If I’m not mistaken, doesn't the Surface Pro 5 use UEFI and not BIOS? If so, then you would need to have your drive setup as GPT (GUID Partition Table) and not MBR (Master Boot Record). Although MBR should work with both.
Instructions from the web: Download Rufus and you can use the portable version (that does not require the installation). Execute and then select your USB device, select GPT for UEFI, FAT32 and select you ISO. Click Start and very quickly you will have a UEFI bootable Windows deployment.
You can download the official ISO directly from Microsoft so please do that.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
This is actually exactly what I do and yes it uses a UEFI
さんによる
@e_ah So did it boot with this method? Sorry, I'm just curious if everything worked out or not. Also, did you insure you enabled secure boot for Windows because you would have had to put it into CSM mode for Linux.
さんによる
コメントを追加
回答を追加する
Ethan Leroux さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 331
