メインコンテンツにスキップ
1.7GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.6 GHz)3MB L3キャッシュ
139回答 すべてを表示
Catalina partition becomes unbootable and turns into "disk0s2"
I was dualbooting my MacBook with Catalina and Mavericks - install went perfectly fine, until I had to restart the computer, and discovered my Catalina partition is completely gone from the boot picker!
At first, I simply thought it was due to APFS not being recognized - however even with a Catalina install USB, it shows the Catalina partition as “disk0s2”, and I can’t write or install to it. Only the second Mavericks partition shows up. Using the diskutil list disk0 command in the terminal (lists partitions on disk0, the main drive in the computer) shows the same partition as FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF
It seems as if the data and the partition itself is still there, only it’s unable to be booted from. Now how do I boot from it? I apologize if the information given isn’t that much. Any help is really welcomed.
Edit - my Mavericks partition is still bootable. Only the Catalina partition - which doesn’t show up in the boot picker in the first place.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
What is the other OS in the other partition?
さんによる
@danj Mavericks. Sorry, just added it.
さんによる
コメントを追加
1 件の回答
Sounds like you had Catalina installed and then added Mavericks which messed up the boot partition. You’ll need to see if installing Catalina again fixes things.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I can't get the Catalina installer to even install to "disk0s2"...
さんによる
@amatsuda223 - You'll need to setup an OS installer USB thumb drive after downloading the installer file from here How to get old versions of macOS and following this guide How to create a bootable macOS Catalina installer drive
さんによる
@danj I already have a Catalina install USB - my plan being to simply reinstall Catalina. It doesn't detect the partition.
さんによる
I've never tried installing an older OS-X onto a system with a newer macOS APFS release so I really don't know how to proceed without redoing the OS. I hope you have a backup ;-{
さんによる
@danj I managed to find this - https://apple.stackexchange.com/question... - seems it could help, unfortunately I got lost halfway through...
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
amatsuda さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 263
