mixing up metal plate screw of battery connector cuz any problem?
Hello, few days ago I replaced the Battery of my Iphone 6 but somehow the shopkeeper lost on the screw of Metal plate shield of battery connector and the phone keep restarting after 10-20 seconds or sometimes in 1mins of screen on. I tried several battery with the same 1 screw metal plate shield every battery shows the same problem even my old original one.
Does Metal plate shield of Battery Connector causing the problem ? how can I fix this $@$* ?
3 件のコメント
If it is the long screw (3,2mm) that is missing then there is no problem, if it is the short screw (2,2mm) then maybe logic board is damage
Leslie Leslie さんによる
@Leslie Leslie both screws are missing. they lost the screw while replacing.
Abir Hasan Chowdhury Babu さんによる
Try to boot your phone with only the battery , display flex connector and dockconnector attached to logic board. No front cam or home button etc. connected to locig board and see if it boot up normally .
Leslie Leslie さんによる
