メインコンテンツにスキップ
2020年11月に発売される13インチMacBook Airは、AppleのArmベースのM1 SoCを搭載し、8コアのCPUと最大8コアのGPUを搭載しています。(モデルA2337 / EMC 3598、Thunderbolt 3ポートを2つ搭載)
20回答 すべてを表示
Is my MacBook Air deformed?
Hello,
I got a new MacBook Air last week. After unpacking it, I noticed that the front right foot did not rest completely on the table (I tried several surfaces). There was about two sheets of paper space. This caused the MacBook to wobble minimally. I applied some pressure to the corner, and the problem was solved.
Yesterday, I had the MacBook with me in my backpack, and when I got home, the front right foot was again not completely on the table. I was able to fix the problem again by applying slight pressure.
However, my concern is that something on the MacBook is deformed and it keeps returning to the deformed stand. Could this be the case? Or does the aluminum not return to its original state? I really need the MacBook right now, so I would rather not return it because I have already had to wait several weeks for this one, if there is a chance that it is defective, I will definitely do it.
What do you think?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I have that exact issue but my Macbook Air hasn’t even left the house yet. It arrived here very well packaged and intact. I do not support the backpack theory.
I also do not wish to send it back for that, but it its at times quite annoying. I would not recommend trying to bend it right. Maybe it is just an overtightened screw, so I would try that first. If i cannot sort in out in the near future I might return it.
さんによる
コメントを追加
4件の回答
最も参考になった回答
The case can warp a bit when pressed unevenly within a backpack! So what you are seeing is this damaged caused by something resting on your system unevenly. Bottom line don’t force stuff your backpack and you should use a protective sleeve (I like the hard shell versions).
While your damage is not extreme too much pressure can damage the display!
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
Ok, thank you very much! So if the MacBook is straightened out now, I don't need to worry about it returning into the deformed state as long as I watch out that no uneven pressure is applied?
さんによる
@atompersone - So bending a paperclip once is no big deal but bending it over and over again ...
NO!! You don't want to bend your system either to correct the damage or cause the damage. Just like the paper clip you'll weaken the case and worse could damage the display $$$$
Bottom line: Get the hard sided sleeve to hold your system in your backpack and don't over do your backpack - Gee I need 20 books but My back pack can't hold them all but I'll try!! Don't!
さんによる
コメントを追加
Hello,
It's been over year by now but I wanted to share my experience, anyway. Perhaps for new device users, just in case. I had this minimal wobble too. I was even checking manufactures tolerances for bottom black legs MacBook Air sits on.
In the end, I went to an authorized service center for warranty repair and they've found out, that the main case was somehow warped by display hinges. Cannot tell if it was warped itself or whether the lid was tightened to the case to much, but, display/lid was changed for a new one in the end.
Since then, no more wobbling!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi. How long did your warranty repair take you? At where I am, it take 7-14 working days to get it repaired.
さんによる
コメントを追加
Hi
Sometimes heat can cause things to expand and deform
Adding to what Dan said pressure can damage the display very easily so what I would do is leave it for a little and if it gets worse have it seen to
Just make sure you don’t alter it in any way as it might void your warranty
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would suggest I lower case replacement. This Is fairly easy to do and I will link the fixit guide below.
MacBook Air 13インチ Late 2020 下部ケースの交換
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I wonder how that could have happened?
さんによる
I doubt replacing the bottom cover will alter things here.
さんによる
コメントを追加
回答を追加する
atompersona さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 28
今までの合計 4,179
