メインコンテンツにスキップ
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
20回答 すべてを表示
Battery not charging to full capacity, why?
I recently just bought a replacement battery for my S7. I have a USB mAh tracker and according to it the amount of mAhs going into the battery has really decreased after calibration, not to mention that it never hit 3000 mAh the manufacturing capacity. I followed the direction on the package for calibration, after charging to 100% for more than 2 hours I used it up till it was empty. Then I charged it to 100% but that totaled 2400mAhs. Now it’s totaling 2000 mAh, I don’t know what’s going on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Assuming this is a third party battery, it's possible it is a purposely mislabelled product. If it's OEM or geniuine Samsung, then I suggest you get the warranty replacement because it's clear that the battery is not up to specs.
さんによる
I just got this battery from ifixit guys. it’s the 3rd replacement and thought to be the closest to the OEM since I can’t find it anywhere. I bought two other batteries before this one from amazon and they all had the same issue but with different numbers of course. Honestly, I’m done opening and resealing my phone, I just wanted to know if there is something I can do to calibrate it right or maybe it’s something with the power consumption of the phone.
さんによる
コメントを追加
1 件の回答
I believe there Is an issue with your battery and you will have to replace it. It is a simple pair with some adhesive holding the phone together but i say repair it yourself for a tiny bit of money
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
さんによる
There is a way to calibrate it.
Here is how
1. Use your phone until it shuts off due to low battery
2. Charge it to 100% uninterrupted.
3. Leave it charging for 2 more hours.
4. Use the phone again until low battery
That should work
Comment again if that did not work.
さんによる
コメントを追加
回答を追加する
Marwan Ali さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
