メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
773回答 すべてを表示
Can I swap the HD from my 15" into my 13" to recover the data?
Hi.
I have a 15”Macbook Pro retina mid 2015 that has given up the ghost, won’t charge, won’t start.
Can I take out the Hard drive and put it in my 13” Macbook Pro Retina Early 2015?
Are they different sizes/fittings? I’m guessing if not it should just boot up from the old hard drive once I swap it over right?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
There may be driver issues or something, but there’s no reason not to try.
さんによる
Without sounding daft (I literally have no idea), wouldn't the drivers be stored on the Hard Drive that I was installing? Where is the OS stored, is that in the Hard Drive?
さんによる
I have no idea either, but it will probably work. And yea the OS is in the hard drive, but it’s also in the computer or something. Anyway you should have little to no problems.
さんによる
Thumbs Up! Cheers
さんによる
コメントを追加
2件の回答
ベストアンサー
Here’s a good reference on the Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs
Both systems 13” & 15” MacBook Pro use a 8.0 GT/s PCIe x4 SSD
So yes they could be switched!
But! Are you using the same macOS on both systems? You may encounter an issue with the version of file system the system is using. Basically, HFS+ Vs APFS. The systems firmware may need to be updated using an external bootable drive.
このアンサーは役に立ちましたか?
スコア 1
11 件のコメント:
I have two other MBP's I could swap the drive into, in fact the one I was going to put it in has recently been updated to 11.1 Big Sur whereas the other one still has 10.11.6 El Capitan, probably better of trying the older OS first as that's more likely to match.
I can see this newer OS is running on APFS but the older one is on HFS+. No idea what the donor mac was on.
さんによる
@pinheadplanet - I would setup an external bootable drive using Sierra (HFS+) Then use the Option (⌥) key to gain access to the Startup manager.
Reference: Mac startup key combinations
さんによる
Do you mean mean put the drive in an external caddy?
さんによる
Thats one way, but I think you can do it with just a USB thumb drive.
さんによる
Sorry, not sure what you mean, how would I do that?
さんによる
6件以上のコメントを表示
コメントを追加
最も参考になった回答
It should work. Be careful of the cables and make sure the device is powered off.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Good point, I probably would have not realised to turn it off
さんによる
コメントを追加
回答を追加する
Kelv さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 88
