メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
467回答 すべてを表示
Why is the 3rd diagnostic led on with external monitor?
I have changed the logic board as the lcd connector was damaged. I have put all the parts back and only two led lights are on and the screen is black. When I connect the external monitor third diagnostic led goes on but there is no image on the external monitor. I. cannot figure out what is wrong. Anybody had similar issues?
Thanks a mil for help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
The onboard diagnostic LED's only really relate to the internal display. You'll need to connect the internal display directly.
さんによる
with the internal display connected I only get two led lights on and strangely so, if I connect the external at the same time it lights up the 3rd light.
さんによる
Time to inspect the LVDS and power cables from the logic board to the display assembly. Make sure they are not bent or damaged in any way.
さんによる
コメントを追加
1 件の回答
With the internal display connected and powered take a bright flashlight held against the screen at a sharp angle are you able to see the faint image of your desktop and it’s icons? Make sure you don’t mar the screen!
If not then you likely have either a bad connection or a bad GPU board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lukasz Gudaniec さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 30
