メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
My traction control and stabilization and abs lights on after bad wind
My stabilization light, traction control and abs lights all came on after a bad wind storm what could it be a sensor issue possibly? It goes off sometimes but come on soon after.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It is possible that this is a sensor issue. I used to have a Toyota van that would disable stability control and traction control if the mass air flow sensor was unhooked, a misfire arose, or if a wheel speed sensor was reading too far out of spec (bad alignment). Best bet would be to get an OBDII code reader (you can find basic ones at places like Walmart for ~$25 and bluetooth ones for a bit more than that online), hook it up, and see what codes come up. You can then look up the code number you get along with your car model on google and should be able to find common causes of the code.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brandie lee さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 24
今までの合計 1,066
