メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
Replace Logic Board w/ Different Speed and RAM or battery replacement
I have a MacBook Pro 13" Retina Display Late 2013 Model A1502 with 2.4GHz and 4GB RAM. It’s not turning on but will charge when magsafe plugged in.
I’m looking to replace the logic board. Hopefully that solves it.'
I want to take this opportunity to upgrade the speed and RAM.
For example, will I be able to switch the old 2.4 logic board with a 2.6 logic board? I don’t want to replace the logic board with the 2.6 and my computer wont work..
Or will I have to stick with the 2.4 and upgrade the RAM only?
How can I test if the battery also needs replacing? When I was able to get it to turn on again I quickly checked the battery cycle and I believe it was at around 300 or 500 cycles. I’m not entirely sure.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Lets give this a try to isolate the problem.
Follow this guide to disconnect the battery MacBook Pro 13インチ Retina Display Late 2013 のバッテリーの交換 follow it dow to Step 6. Now set the system on its side so the MagSafe outlet is up. Press and hold the power button for a good 15 secs to finish discharging the logic. Now plug in your MagSafe charger the system should spontaneously start. Did it? If it did its more likely your charger or battery is messing you up.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Just tried this. It did not power on. So logic boardreplacement then?
さんによる
@pibs - Well ... The issue is within the logic board. Someone with the needed deep skills & tools might be able to fix your logic board vs replacing it.
さんによる
I'm not able to find a place that repairs logic boards near me. They only do replacements. The one I did find online costs a lot on shipping alone. I'll see if cleaning it up will do the trick. But I have a feeling it might need some micro-soldering.
さんによる
コメントを追加
回答を追加する
Paige さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 65
