メインコンテンツにスキップ
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
20回答 すべてを表示
Chemical smell... power supply?
Hello, I started noticing a strong chemical smell coming from the bottom left air-vents of the Thunderbolt Display, but no other signs. The brightness is fine, it powers the MacBook, and no strange behavior. I ordered a PSU replacement, did I make the right choice? Should I also replace the FAN? (but I’m finding only used fans…)
Update (02/18/2021)
@danj Thanks Dan, mine is different. Look at the photo, I marked what seems to originate the bad smell. Is still the component you mentioned before?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
22 件のコメント:
Without opening it up to inspect things it could be anything!
さんによる
Hello Dan thanks, yes it could off course... but I didn't want to open it without first having something to swap, as I have fear for that delicate wires that need to be disconnected to separate the two monitor parts. I wanted to know if, based on experience, this smell could indicate a faulty PSU, as the fan itself shouldn't make burning smell (am I right?), and it pushes air through the PSU pub and then it gets out on the left air vent at the bottom
さんによる
I've replaced more logic boards than PS on these monitors. A fan would not be the first thing I would suspect.
さんによる
Thanks, so I need to open it and check every power rail I suppose? At this time not other sign of malfunctioning (unfortunately). I could keep in using it, but the only thing is I have fear the smell could be toxic.. what did you find on defective logic boards?
さんによる
Burnt caps mostly
さんによる
17件以上のコメントを表示
コメントを追加
1 件の回答
Here’s a marked up image of some of the of the major parts
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vanx さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 6
過去 30 日: 14
今までの合計 1,078
