メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
774回答 すべてを表示
Possible to check new battery just by connectiong to the battery port?
I had got a faulty replacement battery earlier which i had to send back and on the verge of receiving a new one. I was thinking of not taking out the full logic board and just trying the new battery by plugging it into the port first to check if my laptop boots up fine and the battery is detected by the OS. Then if it shows up fine, going ahead with the proper install. Is this doable?
My last replacement battery was not showing up the charge and the laptop shut off instantly as soon as the charger as taken off.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Can't see a reason why you can't do that. Disconnect old battery put the new one in, be careful though as you won't be able to put back cover on. You don't want battery flying around and taking the logic board chunk with it.
Just out of interest, did you check whether your model was in a battery recall programme? If it was you should have had it replaced by Apple for free
15-inch MacBook Pro Battery Recall Program
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey thanks for the reply. I did check the battery recall programme. My model is not included. Let me try the new battery and hope it works out.
さんによる
コメントを追加
回答を追加する
Sayan Ghosh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 46
