メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年10月16に発表されました。モデル番号はA1347でEMC番号は2840です。
M2 SSD upgrade not recognized
Hi everyone!
I'm trying to install an M.2 SSD on my Mac mini, in addition to its 1TB HDD.
I have purchased this adapter: https://pt.aliexpress.com/item/400016101...
And installed it myself. I heard and felt a “click” when plugging it on the Mac Mini, which I thought might be normal.
After rebooting the Mac mini, “ > System information” does not show the NVMe drive, neither does PCI or anything else. There's only the default HDD that comes with the system, but my SSD doesn't show. Disk Utility can't see it either.
The SSD is a WD Green 240GB M.2 2280 SATA III 6Gbps.
I have a gaming PC which recognizes the SSD and is able to format it. I was also able to install Windows on this SSD. Can anyone help me? Thank you!
Update: Apparently the adapter I purchased only works with M-key SSDs. My SSD is a B+M key or something like that. :( I wasn't planning on purchasing another SSD…
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Your system uses PCIe/NVMe not mSATA!
Review this guide on the different custom blade SSD’s Apple has used in their systems The Ultimate Guide to Apple’s Proprietary SSDs
I personally don’t recommend using these adapters and M.2 SSD’s as there have been too many failures.
I recommend sticking with the Apple SSD’s, or using either one of the SSD’s which have been fully reversed engineered from Apples so they work correctly OWC Aura Pro X2 or Transcend JetDrive 850 using Hard Drive Carrier w/SSD Flex Cable, Apple P/N 076-00040
Here’s the guide: Mac mini Late 2014 SSDの交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Antonio Germano さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 30
今までの合計 2,674
