メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Rear glass panel of the iPhone 4s and 4 the same?
I´d like to put a transparent glass rear panel on my new iPhone 4s and just find transparent glass panels for the iPhone 4!
Is it the same? Does anyone of you know a good store to buy?
will i have problems with talking pictures with the transparent panel?
Greetz
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
6件の回答
最も参考になった回答
wow - 35 questions about the iphone 4s and 6 of them are about the backcover.
the dimensions are the same - but thats it - they are different
wait until you get the 4s specific parts (btw - the transparent stuff is normally some plastic crap - the only transparent glass ones are originals - "modified" with aceton)
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
they are not the same. dimension wise, they are. but as far as fitment goes, NOPE.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Here's a good post on why the rear panel on an iPhone 4 won't fit an iPhone 4s. Lots of pics.
http://www.unplggd.com/unplggd/give-your...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i jus bought a transformers back glass.
the two top clips that slide in to secure the back are in wrong place.
The iPhone 4s back glass has them slightly lower... at first i thought it was only one side so i cut that one off but as i slid the back on the glass cracked just below the camera window...
kinda gutted i took it off and cut that side clip off too then put it on... it fits now but i have a little crack near the camera window... but hey it was only £5 so it aint like it cost millions,,, if u do get one make sure you cut the left and right side top clips off then put it on....
also there is a tiny 1mm gap just around the top of my phone now... I'm guessing cuz i didn't cut the clips low enough that it sticks up a little hence the 1mm gap... but meh it looks cool still
^_^ dK
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Luckily, I have the verizon and att iphone 4 as well as the iphone 4S. The back cover from the att iphone didn't fir but the back from the verizon one did!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a Verizon Iphone 4 Black and a Verizon Iphone 4s White and I can verify that the back panels are exactly the same save for a small metal square on the iphone 4 which i assume is a type of heatsink? Check pictures online to see what I'm talking about.
Hope that helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pit さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 36,529
