メインコンテンツにスキップ
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 プロセッサ、発売日は2019年3月19日です。
78回答 すべてを表示
What is this weird tube?
We opened up this machine to inspect the internals and found this strange tube floating freely inside the system. It was completed detached from any other component and was free to move and slide around inside the machine. Does anyone know what this is or why it was in this machine? I’ve attached three pictures of the object.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Alright, I think I figured it out. The loops around the green tube are the same kind of loops you see highlighted in this picture.
There’s also a peel-able adhesive strip on the back, so my guess is this is something the manufacturer sometimes uses to apply those little loops. May have been a leftover piece that accidentally fell into the machine.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Yes! That's an EMI gasket! The tube is pulled out after its mounted. Clearly it was dropped in by mistake!
さんによる
Nice! Thanks for the explanation!
さんによる
コメントを追加
Unless I’m missing something, I don’t see it present in this breakdown:
iMac Intel 21.5" Retina 4K Display 2019 Teardown
From the looks of it, I honestly have no idea what it would be doing inside a PC. Curious to see what it turns out to be but I wonder if someone it was an accidental inclusion from the vendor or someone who worked on it previously?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Zach さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 10
今までの合計 94
