メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
315回答 すべてを表示
Battery Connector damaged on board
As you can see in the photo, the battery connector on the logic board was damaged during disassembly. The edge of the plastic connecter and clip, red arrows, were broken during removal. Anyone have any suggestions on a fix for this problem? The socket is still connected to the logic board, but the plastic retaining clip is damaged.
Appreciate any advice.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
i have the same problem except my connector is actually broken off the motherboard, i can still stick the ribbon cable in but the power isnt registering, and now i have a brand new battery but have to keep it plugged in at all times while im using it, doesn anyone have any tips?
さんによる
コメントを追加
2件の回答
ベストアンサー
Here’s one source for the part FF14A-6C-R11DL-B-3H It’s the same connecter!
I would recommend you find someone with the correct tools and micro soldering skills as this needs special care to remove the old part and install the new one without killing the logic board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
My suggestion is go to a microsoldering tenician to get that fixed… If you try to do it your self it might caused more damaged. Good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Any ideas where to source that part?
さんによる
@Brooks Hill
Dan provided the source for the connector. Unless you really professional with micro soldering skill I would suggest you to just go to yelp and search micro soldering near you, many will give you free quota for price estimate and you can compare the shops based on their reputation and price to decide which one you are going for. Good luck.
さんによる
コメントを追加
回答を追加する
Brooks Hill さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 242
