Screen replacement for A11
I’ve been looking everywhere for a screen replacement for this phone. I’ve cracked my screen. Where can I buy a replacement display?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @alvinhunt
Try searching for SM-A115F LCD display (supplier example only) to find suppliers that suit you. I think that this is the correct model number for the phone.
Check your phone’s model number to be sure and if it is different, search using your phone’s model number rather than just searching for a display using the Samsung phone model name.
このアンサーは役に立ちましたか?
May be a little late to this party, but the a115f is the international version. Depending upon where the OP is from, it could be a115u. These two displays are slightly different sizes.
Roy you are correct. I made that mistake of not looking for my exact model number to my phone and ended up buying the a115f. But I needed the a115u. I got the screen and the whole kit off of Amazon though. It's like $15.
I use a website called mobilesentrix.com for the majority of the parts for my business. But if you buy the one with the attached frame, just make sure you order the right model as your phone or the board wont fit back into the frame. Likely other parts as well but I stopped after I realized my mistake before trying other parts.
Sentrix is usually a good way to go. Mobile Defenders is awesome too.
I got mine on amazon for 35 usd. And it came preinstalled in a frame to where I only needed to transfer the parts over.
Amazon
Brand: ZTOOYO
4.2 out of 5 stars 118 Reviews
Name: for Samsung Galaxy A11 Screen Replacement kit for Samsung a11 a115u Screen Replacement s115dl a115a a115w LCD Display digitizer Touch Screen Assembly with Repair Part Tools 6.4 inch (US Version)
Copy and paste the name into Amazon
このアンサーは役に立ちましたか?
過去 24時間: 10
過去 7 日: 35
過去 30 日: 129
今までの合計 10,804
7 件のコメント
PAST 4 DAY I have cracked my screen.
brucer37 さんによる
MobileDefenders service pack
Joshua Jackson さんによる
What does it cost to replace a screen on a Samsung galaxy A-11
Aubrey Sledge さんによる
IDK. Replacement screens I've found online here in the USA cost around $100 USD if I remember correctly.
Lee Hunt さんによる
But for now, I'm gonna use a screen protector.
Lee Hunt さんによる
2件以上のコメントを表示
